Dual-Environment Configuration
Oracle Utilities Network Management System has the option to use a dual-environment configuration to reduce downtime when installing patches.
Dual-environment configuration requires:
• Two Unix users that are members of the same Unix group. Each user has their own installation of NMS executables.
• Two WebLogic Managed Servers on the same WebLogic node. Each managed server must use a different port.
In this configuration, each environment is numbered 1 or 2 (based on the NMS_ENVIRONMENT environment variable). Only one of these environments can be active at a time.
While one environment is active, most of the steps for installing a patch can be performed on the other environment without interrupting users logged in to the active environment.
The following environment variables must have different values in the separate environments:
• ISISPORT
• ISISREMOTE
• NMS_APPSERVER_PORT
• NMS_ENVIRONMENT
• NMS_MODEL_SOURCE
• NMS_NS_PORT
• ORACLE_READ_ONLY_USER
• ORACLE_READ_WRITE_USER
The following parameters in the CES_PARAMETERS table must have different values in the separate environments:
• WEB_corbaInitRef
• WEB_mapDirectory
• WEB_mapHttpdPort
• WEB_tempDirectory
The $NMS_DATA_FILES/model-sync-filter.cfg must exist and be a valid rsync filter configuration file. This is used by the nms-sync-model script (run by nms-setup and nms-post-setup) when syncing $OPERATIONS_MODELS from the other environment to the current environment. $NMS_BASE/templates/model-sync-filter.cfg.template is a template that can be used to create this file. Run the following command to copy the template:
cp $NMS_BASE/templates/model-sync-filter.cfg.template $NMS_CONFIG/sql/model-sync-filter.cfg
Edit if necessary to exclude any files or directories that should not be copied between environments, such as temporary files. In most cases, the template can be used as-is. Note that there should not be any blank lines in the file. Running nms-install-config will install the file from $NMS_CONFIG/sql to $NMS_DATA_FILES. More information about installing patches in this configuration can be found under Steps to Deploy a Patch Bundle in Dual-Environment Configuration in the Oracle Utilities Network Management System Installation Guide.
