Configuring the Java Common Network Viewer
The Java Common Network Viewer (CNV) uses the same configuration files as Flex for map rendering, settings, the legend, and the hide/display panels. Refer to the Flex configuration instructions and apply changes in networkViewer.jsonc, the same file used to configure the Flex map tool.
To configure options differently for the Java and Flex viewers, use the
appOverrides mechanism described in
Application or Server Specific Overrides. The default Flex configuration disables some power flow glows that are enabled by default for Web Workspace:
"appOverrides": {
"isWws": {
"defaultSettings": {
"map": {
"options": {
"glows": {
"pf_angle_violation": true,
"pf_violations": true,
"pf_warnings": true
If map rendering needs to differ, add an option to the overrides that can be checked in the map configuration. For example:
"appOverrides": {
"isWws": {
"map": {
"options": {
"isWws": true
Referencing Legacy Java Symbols
To reference symbols and conditions used by the legacy Java client, specify the symbol number using the $symbols syntax. For example:
$symbols/3207
The default map configuration uses this fallback when no dedicated configuration exists for a device or condition.
Note: This works for SVGs included through SVGSymbols.properties as well as legacy vector symbols.
