WebLogic Configuration
The Flex SCADA module requires new JMS queues and a JMS Connection Factory.
The JMS message queues are:
• scada-status-queue with a JDNI name jms/scada-status-queue
• scada-ce-queue with a JDNI name jms/scada-ce-queue
• scada-hist-queue with a JNDI name jms/scada-hist-queue
The JMS connection factory is:
• ScadaConnectionFactory with a JNDI name jms/ScadaConnectionFactory
Creating a JMS Message Queue (Non-Clustered)
To create a new JMS Message Queue:
1. Open the WebLogic Server Administration Console.
2. Select Messaging and then select JMS Modules.
3. Select the JMS Module (for example, SystemModule-1).
4. Click New.
5. Select Queue and then Next.
6. Enter the name of the JMS Queue (for example, scada-status-queue).
7. Enter the JNDI name of the queue (for example, jms/scada-status-queue).
8. Click Next
9. Select Create a New Subdeployment. Confirm the sub deployment name matches the queue name.
10. Click OK
11. Select the target deployment (for example, JMSServer-1).
12. Click Finish
Creating a JMS Connection Factory (Non-Clustered)
To create a new JMS Connection Factory:
1. Open the Weblogic Server Administration Console.
3. Select the JMS Module, (for example, SystemModule-1).
4. Click New.
5. Select Connection Factory and then Next.
6. Enter the name of the Connection Factory (for example, ScadaConnectionFactory).
7. Enter the JNDI name of the connection factory (for example, jms/ScadaConnectionFactory).
8. Confirm that XA Connection Factory Enabled is selected.
9. Click Next.
10. Click Advanced Targeting.
11. Click Create a New Subdeployment.
12. Confirm the sub deployment name matches the queue name. Select OK.
13. Select the target deployment (for example, JMSServer-1).
14. Click Finish.
15. Select the newly create connection factory on the Summary or Resources.
16. Select the Default Delivery tab.
17. Set the Default Delivery Mode to Non-Persistent.
18. Click Save.
Clustering
In a WebLogic clustered environment, the JMS Module, Queues, and Connection Factory need to be targeted to all nodes in the cluster. This section assumes that the WebLogic Cluster is already present in the configuration.
Creating the JMS Module, Connection Factory, and Distributed Queues (Clustered)
1. Open the WebLogic Server Administrator Console.
2. Select Messaging, and then select JMS Modules.
3. Select New.
4. Enter the Name of the Module.
5. Click Next.
6. Select All servers in the cluster.
7. Select Next.
8. Select Would you like to add resources to this JMS system module?
9. Select Finish.
10. Select New.
11. Select Connection Factory, and then click Next.
12. Enter the name of the Connection Factory (for example, ScadaConnectionFactory).
13. Enter the JNDI name of the connection factory (for example, jms/ScadaConnectionFactory).
14. Confirm that XA Connection Factory Enabled is selected.
15. Click Next.
16. The targeting option All servers in the cluster should be pre-selected. Select Finish.
17. Select the newly create connection factory on the Summary or Resources.
18. Select the Default Delivery tab.
19. Set the Default Delivery Mode to Non-Persistent.
20. Click Save.
21. Click New.
22. Select Distributed Queue, and then click Next.
23. Enter the name of the JMS Queue (for example, scada-status-queue).
24. Enter the JNDI name of the queue (for example, jms/scada-status-queue).
25. Click Next.
26. The targeting option All servers in the cluster should be pre-selected.
27. Select Finish.
28. Repeat steps 21 through 27 until all three queues are created (scada-status-queue, scada-ce-queue, scada-hist-queue).
Configuring the Flex SCADA / Edge DERMS Synchronous JMS Timeout
Use the oracle.nms.jms.synchronousTimeoutMs managed-server JVM startup argument to set the maximum time, in milliseconds, that Edge DERMS waits for a response to a synchronous JMS request.
The default timeout is 60000 milliseconds. Specify a value of 60000 or greater; values below 60000 are treated as 60000.
For example, to set the timeout to 120 seconds, add the following to the applicable managed server startup arguments:
-Doracle.nms.jms.synchronousTimeoutMs=120000
Restart the managed server after changing this startup argument.
Disabling Flex SCADA on a WebLogic Managed Server
The Flex SCADA services must only running on one active managed server at any time and should be disabled on managed servers used to service flex operations or OMA for instance.
To disable the Flex SCADA services add the following command line argument to the web logic start up command line arguments:
-Dnms.disable-flex-scada-static-service=true
Configuring Secure FEP Connections
In order to configure secure communications between the NMS system and the FEP the keystore and truststore must be configured in WebLogic.
2. Select Servers and select the server hosting Flex SCADA.
3. Select Keystores.
4. Set the Keystores option to either Custom Identity and Java Standard Trust or Custom Identity and Custom Trust.
5. Enter Custom Identity Keystore location, Custom Identity Keystore Type, Custom Identity Keystore Passphrase and Confirm Custom Identity Keystore Passphrase. The custom identity keystore must contain the public and private key of the WebLogic server.
6. Enter the Trust Keystore details. If using the Java Standard Trust then the location and keystore type are automatically populated to $JAVA_HOME/jre/lib/security/cacerts. If the Java Standard keystore is held in any other location then the Custom Identity and Custom Trust option must be chosen.
The Trust Keystore must contain the Certificate Authority Certificate used to sign the FEP's public keys.
7. Click Save.
8. Select the SSL tab.
9. Enter the Private Key Alias which the private key is stored under in the Custom Identity Keystore.
10. Enter the Private Key Passphrase and Confirm Private Key Passphrase.
11. Click Save.
