Configuring Edge DERMS JMS Resources
Edge DERMS requires a JMS connection factory and two JMS queues. Configure these resources for the WebLogic environment that hosts Edge DERMS. The connection factory is DrmsConnectionFactory, with JNDI name jms/DrmsConnectionFactory. The queues are:
• drms-reply-queue, with JNDI name jms/drms-reply-queue.
• drms-status-queue, with JNDI name jms/drms-status-queue.
The following procedures apply to both single-server and clustered environments. Select the appropriate JMS module for your environment; the module names shown are examples.
Create the JMS Connection Factory
1. Open the WebLogic Server Administration Console.
2. Select Edit Tree.
3. Select Services, and then select JMS Modules. Select the JMS module (for example, SystemModule1), and then select Connection Factory.
4. Select New.
5. Enter DrmsConnectionFactory as the name.
6. Select Create.
7. Select Default Targeting Enabled.
8. Enter jms/DrmsConnectionFactory as the JNDI Name.
9. Select Save.
10. In Default Delivery, set the default delivery mode to Non-Persistent.
11. Select Save.
12. In Transaction, ensure that XA Connection Factory Enabled is selected.
13. Select Save.
Configure the JMS Subdeployments
Create a subdeployment for each of the following names:
• DrmsConnectionFactory.
• drms-reply-queue.
• drms-status-queue.
For each subdeployment, complete the following procedure:
1. Select Services, and then select JMS Modules. Select the JMS module (for example, SystemModule-1), and then select Sub Deployments.
2. Select New.
3. Enter one of the subdeployment names listed above.
4. Select Create.
5. Choose the target for the environment. For a non-clustered environment, select the JMS server associated with the managed server (for example, JMSServer-1). For a clustered environment, select the cluster name as the target.
6. Select Save.
Repeat this procedure for the remaining subdeployment names.
Create the JMS Queues and Commit Changes
1. Open Unified Queues in the JMS module (for example, select Services, and then select SystemModule-1 and Unified Queues, in that order).
2. Select New.
3. Enter drms-status-queue as the name.
4. Select Create.
5. Enter jms/drms-status-queue as the JNDI Name.
6. Set the subdeployment to drms-status-queue.
7. Select Save.
8. Create the second queue using the same procedure. Enter drms-reply-queue as the name, jms/drms-reply-queue as the JNDI Name, and select the drms-reply-queue subdeployment. Save the queue.
9. Select the basket icon at the top right, and then select Commit Changes.
