Mobile Gateway Architecture
The Mobile Gateway can be deployed on premise or in the cloud:Mobile Gateway Architecture showing HTTPS requests through RESTful API calls.
OMA Network Overview - In the Cloud architecture diagram
This architecture addresses many security concerns limiting the access from the Internet to the corporate network.
The cesejb application also validates EJB method calls received through the OMA/Flex request queue against the configured EJB allowlist. In production, an unlisted method is rejected when learning mode is disabled. Flex requests undergo additional group and user-type validation. See "EJB Allowlist and Flex Access Validation" in NMS Server Configuration for setup, production enforcement, and troubleshooting.
How Operations Mobile App devices connect to the NMS instance:
1. The Operations Mobile App client device connects to a dedicated WebLogic Managed Server, called the NMS WebLogic Mobile Gateway (WLMG), using HTTPS making RESTful Web Service requests.
2. The WLMG places Operations Mobile App client requests on the JMS in-memory “requests” queue.
3. The primary NMS WebLogic Managed Server (WLMS) connects to the JMS “requests” queue on the WLMG as a JMS client using the WebLogic t3s protocol and pulls requests off the “requests” queue and processes the requests via the normal channel from WLMS to NMS Services.
4. The WLMS then places responses to valid Operations Mobile App client requests on the parallel JMS in-memory “responses” queue – in a similar fashion to how the “requests” queue is handled.
5. The WLMG replays to the HTTPS RESTful Web Services request with the WLMS responses
6. The Operations Mobile App client device takes the HTTPS response and processes it on the device.
Notes:
• It is recommended to have an Oracle HTTP server or other reverse proxy server to further isolate OMA from the internet.
• There should be a firewall rule that allows only access to the https port from the internet (all other ports should be blocked).
