Client PWA Installation Instructions
OMA is a PWA application and can be installed on the following systems.
OMA installation is done by using the device's browser and connecting to the OMA application website.
OMA has a standardized installation process for Android, iOS, iPadOS, and Windows:
1. Launch the browser to the HTTPS server where OMA is installed (for example, https://host.com:8889/mobile/oma2/www/index.html).
2. On launch, OMA displays the PWA installation page. OMA downloads the PWA files into browser cache storage. After the download is complete, OMA reports that installation options are ready.
3. On iOS and iPadOS:
a. Open the iOS share menu.
b. Select Add to Home Screen.
c. Press the OMA icon on the home screen to start the PWA.
4. On Windows with Chrome:
a. You will be presented with an installation dialog box. Click the Install button to install it on the device.
b. The PWA will close in the browser tab and open as a standalone PWA app.
c. The PWA will be given a start menu option from where you can launch the app, pin it to the taskbar, pin it to the start menu, or open the location of the app and copy it to the desktop.
5. On Windows with Microsoft Edge:
c. An installation options dialog is also displayed.
6. On Android Chrome:
a. You will be presented with an installation dialog. Click the Install button to install it on the device.
b. A small temporary message will indicate the app is being added to the home screen.
c. Close the browser and the home screen should be focused on the location of the OMA app icon. Feel free to drag it to any location on the home screen(s).
d. To launch OMA as a PWA, just click on the OMA launch icon.
