Client PWA Update Instructions
If the client is connected to the network, then on application startup OMA checks the HTTPS server for a newer PWA version. If a newer version is found while the user is still in the startup or login flow and has not logged in, OMA automatically installs the update and reloads the application. The user does not need to select the install update notice in this case.
After the user leaves the login page or is already logged in, OMA does not automatically install a newer version. OMA downloads the update and displays an install update notice in the header. The user can continue using OMA, and the update is applied when the user restarts OMA or selects the install update notice.
If OMA is running from a native wrapper, the wrapper may restart or relaunch OMA as part of applying the updated PWA.
