Web Workspace / Core Outage Management System (OMS)
Enhanced Support for Hotline Warnings
This feature supports the process of automatically creating a Hot Line Warning switching sheet.
When specifying the work location in the Map, the system identifies:
• The upstream circuit breaker.
• Any reclosing devices.
• Any downstream normally open points (boundary points) to neighboring circuits.
Once identified, the system automatically creates a Switching Sheet for the Hot Line Warning work. This provides a more safety-conscious and efficient means of creating this kind of switching plan.
Printing Damage Assessments
This feature enables users to print and email damage assessments to Repair Crews. This includes the ability to choose which sections of the damage assessment to print, including clear image attachments.
This feature is implemented in the Web Workspace (Java) client and in Flex Operations.
Consolidate and Augment the Event Details Event Log
Although event information can be populated and viewed in different places in the Event Details, users need to be able to view a single, comprehensive log – a history or audit trail of all key activities through the life of the event – which can be sorted, filtered, and exported.
This feature augments the Event Details' Event Log to provide a single, consolidated view of the event history.
Optimize Model Generation in the Common Network Viewer (CNV)
This feature augments NMS so Model Build Service (MBService) produces GeoJSON files to support the Common Network Viewer. This improves performance when doing a model build or when performing model edits on the Map.
Warn User If They Try to Complete a Switching Sheet with Existing Placed Tags
This feature displays a warning if a user attempts to complete a switching sheet and not all tags placed by steps in that sheet have been removed.
Closing Remaining CNV Gaps to Legacy Java Viewer
This feature closes most of the remaining functional gaps between the CNV and the legacy Java viewer. Once complete, all functionality currently supported in the Java viewer will be supported in the CNV, which in turn would enable the old Java viewer technology to be deprecated.
Remaining known functional gaps with the legacy viewer include:
• Ability to hide/display specific Fault Location Analysis (FLA) symbols on demand.
• Ability for users to move calls from one event to another via drag and drop.
• Ability for users to move a crew from one event to another via drag and drop.
• Ability for users to move Damage Assessment conditions (other conditions can be moved).
• Ability to support Lenses.
• Ability to display an outage overview when zoomed out.
Oracle intends to close these remaining gaps in 25.12.0.1 patches.
