Flex Operations
Several features previously available only in the Control Room client have now been implemented in Flex Operations. These features focus on Outage Management functions and framework-level features added to Flex Operations to emulate functionality that already exists in the Control Room client.
Study Mode in Flex Operations
This feature enables more efficient and intuitive switching sheet creation in Flex Operations, by simulating the effect of switching steps as if they had been executed. When in Study Mode, a colored border is displayed around the Switching Sheet, Map, Operate Device dialog, and Safety Document windows. Users can toggle in and out of study mode, and reset the model to a copy of the Realtime or Nominal network model.
Printing Damage Assessments in Flex Operations
This feature enables users to print and email damage assessments to Repair Crews. This includes the ability to choose which sections of the damage assessment to print, including clear image attachments.
This feature is implemented in the Web Workspace (Java) client and in Flex Operations.
Crew Info Tool in Flex Operations
This feature enables Flex Operations users to view detailed crew information and event assignments for the currently selected Crew. Emulating the Control Room client equivalent capability, Crew status and event updates can be entered from the Crew Info tool, without the need to drill down into the Event Details.
Users can choose to arrange the Crew Info tool embedded within the Event List (right or bottom) or undocked in its own floating window.
Event Reading Pane in Flex Operations
This feature enables Flex Operations users to display an event Reading Pane, showing key event information for the currently selected event. Emulating the Control Room client equivalent capability, Crew status updates can be entered from the Reading Pane, without the need to drill down into the Event Details.
Users can choose to arrange the event Reading Pane embedded within the Event List (right or bottom) or undocked in its own floating window.
Move Customers to a Different Supply Point in Flex Operations
This feature enables Flex Operations users to move customers from one supply point to another, as per the existing Control Room client.
View Documents for the Selected Device in Flex Operations
This feature provides the ability for a user to select a device on the Map and see a list of documents associated with the device.
Users can also associate other available documents with the selected device on the Map.
View Device Event History in Flex Operations
This feature enables Flex Operations users to view the event history for a selected device on the Map. This feature provides equivalent capability to the existing tool in the Control Room client.
Filter Row for Tabular Displays in Flex Operations
This framework-level feature adds the filter row to all Flex Operations tabular displays, providing equivalent capability to the Control Room client tabular displays.
The filter row can be hidden or displayed on each tabular display, and allows multi-selection of items within each table column (like in Microsoft Excel), partial-match filtering, and multi-column filtering.
Summary Count Panel for Tabular Displays in Flex Operations
This framework-level feature adds a Summary Count panel to the top of the Flex Operations Event List, providing equivalent capability to the Control Room client’s Work Agenda Summary Count grid.
This feature is implemented as a framework-level feature, meaning that other main tabular displays can also be configured with Summary Count panels.
Users have the ability to show/hide the Summary Count Panel, and choose which count “badges” to display. Users can also click on each badge to temporarily filter the tabular.
Two New Columns in the Flex Operations Event List – Device Category and Device Type
This feature adds two new columns to the Flex Operations Event List.
• Device Category is a high-level categorization of events based on the interrupting device. Examples include transformer, fuse, switch, and overhead (OH) conductor.
• Device Type is a lower-level breakdown of device types. For example, a Device Category of “Transformer” might have Device Types of “Pad Mount Transformer,” “Overhead Transformer,” and “Substation Transformer.”
The addition of these columns enables better breakdown and filtering of events according to device categories and device types. This feature is only available in Flex Operations.
