Edge DERMS
Automated Service Requests
Managing DER communications at scale requires a clear way to distinguish transient issues from conditions requiring operational follow-up. This feature brings detection, service-request initiation, and aggregated alerting into one controlled workflow.
• This feature identifies defined communication-loss conditions and initiates the related service request.
• It provides configurable alerts for accumulated communication-loss events.
Front-End Processor (FEP) Management
This feature supports the configuration and management of Front-End Processor connections used by Edge DERMS. Users can maintain the connectivity information needed to communicate with aAggregators/Head End Systems and other related systems.
SunSpec Modbus Device Registration
This feature supports registering SunSpec Modbus devices in Edge DERMS. Users can establish the device information needed for supported device data exchange.
Head-End System (HES) Service Capability Management
This feature provides a way to define and manage the services available from a Head-End System. Users can use those capabilities when configuring supported Edge DERMS interactions.
Live Energy Connect (LEC) Log Access
This feature enables authorized users to access Live Energy Connect logs from Edge DERMS. It improves the ability to investigate integration behavior without requiring direct access to the logs on the server.
Multi-Day DER Events
This feature allows users to create Edge DERMS events that span more than one day. Events can now begin on one day and complete on another to support longer event hours that include DERs such as Energy Storage devices.
Holiday Run-Day Options
This feature adds holiday support to strategy run-day configuration. Users are able to define strategies that run on days designated as holidays.
Individual-Device Optimization
Different grid constraints and aggregator capabilities may require dispatch decisions at a more granular level than existing program or population groups allow. This feature broadens the inputs and controls available for creating and resolving optimization, ideally for smaller events.
• This feature allows individual devices to be included in an event.
• It supports the associated configuration and constraint information needed to evaluate those devices.
