SCADA
NMS v25.12.0.1 provides significant enhancements for SCADA. The main enhancements are described below.
SCADA Status Symbols in the Viewer
This feature displays SCADA status visually in the viewer for SCADA-enabled devices. Operators are able to assess the connection status directly from the device symbol, reducing reliance on codes or tables.
Substation Alarm Overview
During fault investigation, operators need a concise operational picture of a substation's alarms rather than relying on long, fragmented alarm lists. This feature creates a configurable visual alarm overview tailored to each substation.
• This feature presents alarm information in a substation-focused overview.
• It includes supported alarms that are associated with the substation and any individual device within that substation.
• It allows the display to be configured for operational context.
Device Alarm Status in the Viewer
This feature displays an improved indication of the alarm status of a device in the Network Viewer. Operators are able to recognize multiple alarm conditions on devices.
Search SCADA Status by Device
This feature allows users to search SCADA information by device. It helps operators find the relevant SCADA status and associated information more directly. The information for the device is then displayed in a dedicated Device Monitor display.
Historical Trends
This feature provides access to historical trend information for supported SCADA data. Users are able to review prior values for selected measurements to help with operational investigation and expected measurement behavior.
Inter-Control Center Communications Protocol (ICCP) Transfer-Set Descriptions
This feature supports descriptions for ICCP transfer sets. Users are able to identify the purpose of configured transfer sets more clearly during administration and investigation. 
SCADA Simulator
The SCADA Simulator will provide testing capabilities for Flex SCADA. It supports the DNP3, IEC-101 and IEC-104 protocols and allows users to initiate unsolicited commands as well as measurement updates to inject into Flex SCADA. It will also respond to control requests issued from Flex SCADA. Integration to EMService is also available to support realistic measurement values.
