Live Energy Connect
LEC v25.12.0.1 provides enhancements to support SCADA and Edge DERMS features. The main enhancements are described below.
Open Automated Demand Response (OpenADR) Support
Utilities using demand-response resources need a consistent way to exchange event information with supported third-party systems. This feature establishes an extensible OpenADR-based integration foundation in Live Energy Connect.
• This feature supports the required OpenADR event interactions.
• It provides the integration foundation for supported external demand-response systems.
SunSpec Modbus Data Model and Messaging
DER integrations require a consistent model for converting device register information into usable operational data and controls. This feature adds the SunSpec Modbus data and messaging foundation between Edge DERMS and LEC.
• This feature provides the SunSpec Modbus data model.
• It supports the related messaging used to exchange supported DER information.
Secure ICCP
Utilities exchanging control-system data over ICCP need communications that meet their security requirements while remaining manageable by administrators. This feature provides the secure-connection framework for Linux-based LEC.
• This feature supports secured ICCP connections for Linux-based LEC deployments.
• It provides the associated configuration and certificate-management capabilities.
Dynamic Point Updates
Live Energy Connect now supports the dynamic updating of point configuration from Flex SCADA allowing the new configuration to apply as soon as it is received without restarts of the protocol PODS.
