Power Flow Solutions Details
Power Flow solutions details feature allow users to request and review power flow solution details to identify areas of the model with data problems. Non-Administration users have access to Power Flow Solution Details for all real-time based power flow solutions, which are auto-generated; Administration users also have access to real-time Power Flow Solution Details and also have the ability to force generation of details for forecast and study mode power flow solutions.
The solution details page is available from the Viewer's Device Details Power Flow Results tab, from the Feeder Load Management Feeder Load Overview table, and from the Feeder Load Summary.
Viewing Power Flow Solution Details from the Viewer
1. Start the Viewer.
2. Click the Device Details button () to enable Device Details.
3. Click the device.
4. Click the Power Flow Results tab, if not active.
The Power Flow Results tab is populated with the calculated results.
5. Click the Feeder Errors, Warnings, and Details button () to open the Feeder Errors, Warnings, and Details dialog box.
6. Select the Solution Details tab.
Note: When opened through Feeder Load Management, Power Flow Solution Details opens in a combined FLM Feeder Errors, Warnings, and Details dialog box, which includes Solution Details, Errors & Warnings, and Island Info tabs. Select Island Info to view the sources and feeders in the power flow island. Please see Feeder Errors and Warnings for more information on the Errors and Warnings tab.
Viewing Power Flow Solution Details from the Feeder Load Management Tool
1. Open Feeder Load Management.
2. Select a row in the Feeder Load Overview table.
3. Select Show Errors and Statistics... from either the Actions menu or the right-click option menu.
4. When the dialog box opens, select the Solution Details tab.
Viewing Power Flow Solution Details from the Feeder Load Summary Tool
1. Open Feeder Load Summary
2. Select a row in the summary table.
Note: When opened through Feeder Load Summary, Power Flow Solution Details opens in a combined FLM Feeder Errors, Warnings, and Details dialog box, which includes Solution Details, Errors & Warnings, and Island Info tabs. Select Island Info to view the sources and feeders in the power flow island. Please see Feeder Errors and Warnings for more information on the Errors and Warnings tab.
Using Power Flow Solution Details Window
The solution page includes:
• Title with load scenario, time for the solution, and starting device when the request was sent from the Viewer or starting feeder when the request was sent from FLM. The title also includes the solution status device when the request was sent from the Viewer.
• SCADA Iteration rows and PF Engine Run rows are interleaved on the summary page. The most recent entries appear first. SCADA Iteration rows describe load-allocation passes, including the maximum scale factor, solution status, and last SCADA time.
• The summary header reports PF Engine Runs, PF Engine Iterations, Control Emulation Iterations, Tap Changes, and Control Emulations. Each PF Engine Run reports its PF Engine Iterations, Tap Changes, Shunt Changes, and DER Changes. PF Engine Runs count calls to the power flow engine; PF Engine Iterations count the numerical iterations within those calls. Tap Changes are counted separately from shunt and DER Control Emulations. Select Engine Iteration Details for a run to view its numerical iterations and their voltage-change and transformer tap-change information. Select a PF Engine Iteration link to inspect the detailed voltage, power-mismatch, and regulation-move information for that iteration.
• Select SCADA Details for a SCADA Iteration when mismatch details are available to inspect the devices and phases with allocation mismatches, including the calculated value, measurement, scaling factor, and mismatch percentage.
• Control Emulation Details is available only for a run with shunt or DER changes. Select it to inspect the control changes for that run. Shunt control details show the regulation type, measured attribute value, off and on thresholds, and the position change, such as Off to On. These are shunt position changes, not capacitor step counts. DER details show reactive output, the reactive-power increment, average voltage, and target voltage.
• Device hyperlinks focus the Viewer on the selected device. Click Back to return to the summary page.
