Enabling and Disabling Optimization Devices
From the Control Tool
You can enable or disable devices for Optimization actions by selecting either Enable Optimization or Disable Optimization, respectively, from the Control Tool's Optimization... button. These buttons are displayed for all optimization-capable devices. When a device is disabled from optimization, a condition flag is shown on the Viewer adjacent to the device.
Capacitor Automatic Control and Optimization
For capacitors, Automatic Control is the single gate for normal local regulation (Controls 1 and 2). When Automatic Control is On, normal local regulation is active and real-time Optimization does not operate the capacitor. When Automatic Control is Off, normal local regulation is suppressed and the capacitor may be considered for real-time Optimization, provided valid position feedback is available and all other eligibility checks pass. Turning Automatic Control Off does not by itself enable Optimization.
An existing project local-control indication, such as a physical point named LVC, can be mapped to the product Automatic measurement. A second dedicated Automatic point is not required when the existing indication supplies that state. There is no separate Local Voltage Control product measurement. The project-configured Optimization Disabled indication remains a separate veto: when asserted, it excludes the device from Optimization.
Emergency Control is evaluated before normal Controls 1 and 2 and remains available whether Automatic Control is On or Off. Normal controls apply only when Automatic Control is On and Emergency Control has not already determined the capacitor state.
During a temporary bad-quality Automatic sample, Power Flow and Optimization use the last accepted good Automatic value. The current raw value and its bad quality remain available for diagnosis.
These capacitor Automatic Control states are separate from the feeder Optimization mode (Manual or Automatic), which determines whether a generated plan requires operator execution.
From Grid DERMS Management
In addition to the above, DERs are coordinated with DERMS and have their own management interface see Understanding Grid DERMS Management.
Setting Optimization Mode on Feeders
You can set individual feeders to Automatic (Slow Cycle), Automatic (Fast Cycle), Manual (Slow Cycle), or Manual (Fast Cycle), or Disable mode with the Configuration Assistant's Feeder Management tab (see Using the Feeder Management Tab for details). However, the status of the other feeders on the same substation Load Tap Changer can influence the Optimization mode of the feeder.
AMI Bellwether Voltage
Overview
In real-time mode, Optimization is capable of making use of bellwether meter voltages. The voltages are used as an input to the optimization algorithm to ensure that voltage violations are not created on the secondary network serving customer meters. By using voltage telemetry, the Oracle Utilities Network Management System can begin to learn the difference between the solved power flow voltage versus the actual telemetered voltage and make estimates as to what the secondary service drop may be between a service transformer and the bellwether meter location. If utilities strategically choses bellwether meter locations at points that experience the lowest voltage on a feeder, it will help ensure that the optimization does not create voltage issues in scenarios like CVR where the voltage is lowered to reduce demand. Oracle recommends that utilities chose two to three metering points per regulation zone on a feeder. These voltages can come from field devices (sectionalizer, recloser, capacitor, and so forth) that are capable of telemetering voltage but would be most useful at customer meters.
Usage in Optimization
Before the Oracle Utilities Network Management System attempts to optimize an area of the network, it checks to see which bellwether meters have had voltages updates within a configurable time period (the default is 15 minutes) since only up to date telemetry will be utilized. Once the list has been received, if any of the telemetered voltage values differ by a configurable percentage from the power flow calculated voltages, the optimization will not be run in that area because there is either a severe power flow data issue or an issue with telemetry accuracy; in either case, the optimization will not be run since the results could have a negative impact on the performance of the feeder. Utilizing only the valid telemetered voltages, the secondary impedance drop is estimated at each of the bellwether locations and used as input into the optimization algorithm. For example, if the solved voltage at a meter is 95 percent of nominal and the telemetered is 94 percent of nominal, the Oracle Utilities Network Management System knows there is a one percent discrepancy between actual and solved. Therefore, when running an objective (such as CVR), the algorithm will ensure that this difference is taken into account when ensuring a particular plan does not create low voltage conditions. The Oracle Utilities Network Management System captures a snapshot of the bellwether voltages before and after plan execution so you can review the results to determine the effectiveness of the plan and to assure you that low voltage conditions were not created.
