Managing Outage Events
Managing outage events requires interaction between the Events list, Crews list, Event Details, and the Map. The rest of this section explains these tools and provides procedures for performing actions in the Flex Operations client. All of the actions may be performed in the NMS Web Workspace with Switching client and have been described in detail in the relevant chapters (Managing Events with Web Trouble Management, Managing Crews with Web Trouble Management, and Web Switching Management). The focus of this chapter is on taking advantage of the unique features that Flex Operations offers.
Working with the Events and Crews Tool
Events and Crews are displayed together (in a tab view) because of their close association when managing outages.
Note: You can change the relative height of the Events and Crews panes by dragging the separator bar up or down.
The columns in the Events pane and in the Crews pane are the same as the Web Workspace Work Agenda and Crew Actions List View, respectively.
• See Understanding Work Agenda Data Display for descriptions of the columns in the Events pane.
• See Understanding the Crew List View for descriptions of the columns in the Crews pane.
• Common outage management procedures are documented in Chapter 3, Managing Events with Web Trouble Management.
Viewing Events and Crews
The Events and Crews tab is displayed by default, but may be closed. If you want to open it again, select Events and Crews from the Tool Selector (). Events, such as outages, are displayed in the Events pane; crews are displayed in your Crews pane.
Notes:
• You only see events and crews in control zones that you have subscribed to.
• Right-click an event row to see the actions available for the event.
• Double-click an event row to view its Event Details page.
Using Event Summary Items
The summary row on the right side of the Events toolbar provides at-a-glance counts and totals for event data. The default summary items are:
• Out: Estimated Customer Outages
• Calls: Customer Calls
• Pri Calls: Priority Calls
• Emer Cust: Emergency Customers Out
• Med Cust: Medical Customers Out
• Key Cust: Key Customers Out
• Sens Cust: Sensitive Customers Out
• Disp Crews: Crews En Route/On Site
• Priority To Do: Events To Do with High Priority
• Normal To Do: Events To Do with Normal Priority
• In Progress: Events In Progress
Feeder, Recloser, and Fuse event counts are also available but are hidden by default. Summary items with a zero value are not displayed. Configured warning and error formatting highlights summary values that require attention.
Hover over a summary item to display its full description and whether it summarizes the current filtered view, all loaded data, or data matching a custom filter. Where navigation is available, click the summary item to filter the Events table to the relevant events. The table may also be sorted to bring the most significant values to the top.
To customize the summary row, select Organize Summary Items... from the Actions menu. In the Summary Items dialog box, select or deselect items to show or hide them. Reorder items by dragging them or by using the positioning buttons. Your choices are saved as personal preferences. Click Defaults to restore the configured visibility and order.
