Working with Event Details
The Flex Operations Event Details tool allows you to view and update event information from a page that is very similar to the Web Workspace Event Details (see Understanding Event Details for more information). Its window has key event information in the top pane and a set of tabs with different types of discrete data for the event below.
Opening Event Details
You can access Event Details from the Events and Crews lists, Event and Crews reading panes, and Map.
Opening Event Details from the Events List
From the Events List, you can open Event Details for an event by doing any of the following.
• Double-click an event row.
• Select Edit from the Actions menu.
• Right-click an event row and select Event Details... from the context menu.
Opening Event Details from the Crews List
For a crew that is associated with an event, you can right-click the crew row and select Show Event Details... from the Manage [OMS Crew ID] on [Event ID] context menu option. The Show Event Details... option is also available from the Crews List Actions menu.
Opening Event Details from the Event Reading Pane
To open Event Details from the Event Reading Pane, open the Events list and use Reading Pane Options to show the Event Reading Pane. Select the event to display in the reading pane, then select Open Event Details (the pencil icon) from the Event Reading Pane toolbar. Event Details opens for the event displayed in the reading pane.
Opening Event Details from the Map
If you have the Map focused on an event, you can select the event symbol and then select Open Event... from the Selection pane's Event menu.
Understanding Flex Operations Event Details Information Pane
The Event Information pane at the top of Event Details, contains the following information.
• The Event # is the number the system has assigned to the event.
• The Phases Out is the event phases.
• The # Calls is the number of calls for the event.
• Customers Out contains the estimated number of customers experiencing an outage for this event.
• The # Emer., # Med., # Key, and # Sens. list the critical customers affected by the event.
• Start Date contains the date and time when the event began. This field is editable except for switching events. For switching events, you must edit the Completed Date in the switching step itself. See Steps Tab for more information.
• Est Restore Date contains the estimated restore date for the event. You may edit or clear the estimated restore date using standard Date/Time controls (see Using Date/Time Pickers for details).
• Restore Date contains the date and time of event restoration (that is, when the outage area was restored). This field is editable except for switching events. For switching events, you must edit the Completed Date in the switching step itself.
• Est Time to Repair contains the estimated time to repair the event.
• The Device is the name and type of device associated with the event
• The Sheet # is the switching sheet number associated with the event, if any. The switching sheet number is prefixed by the switching sheet type.
• Clues contains any clues contained in the customer calls.
• Zone displays the control zone where the associated device is located.
Understanding Flex Operations Event Details Tabs
Flex Operations Event Details provides many of the tabs available in the Web Workspace. One key difference is that Flex Operations displays tabs for the calls and customer information available through the Trouble Info tab in the Web Workspace Event Details.
• Job Actions: see Using the Job Actions Tab.
• Completion Actions: see Using the Completion Actions Tab.
• Equipment Failure: see Using the Equipment Failure Tab.
• Damage Assessments: see Understanding Damage Assessments.
• Event Log: see Using the Event Log Tab.
• Attachments: see Working with Attachments for details on working with Flex Operations Event Details Attachments.
