Adding Damage Reports
1. In the Map, click to select a device or conductor, then from the
Selection Panel, select
Add Damage Report... from the
Damage menu.
2. The new Damage Assessment is displayed in a tab in the Workspace.
Record Patrolling Updates
You can add and update patrolling conditions.
Adding a Patrolling Condition
1. In the Map, click to select a device or conductor.
2. From the
Patrol Status, and then select the type of patrol condition to add:
Add Patrolling Condition: Adds the condition in a
Patrolling state.
Add Device Patrolled: Adds the patrolling condition of
Device OK.
Network Patrolled: Adds the patrolling condition to
All OK. Highlights all network downstream of the selected device in a patrolled color.
Updating the Status of a Patrolling Condition
1. In the Map, select the patrolling symbol.
2. From the
Selection Panel Patrolling panel, select
Edit Condition from the
Tag/Note menu.
3. In the Patrolling Condition Details dialog box, change the condition status and add a description in the Text field, then click OK.
Removing a Patrolling Condition
1. In the Map, click to select a patrolling symbol.
2. From the
Remove Condition from the
Tag/Note menu.
Feeder Highlights
You can highlight an entire feeder by hiding/subduing the other feeders.
For a selected device or conductor, click
Feeder Highlights (
) then click
Highlight Feeder or press
F. Other feeders will be displayed less prominently, but still be selectable (so you can highlight additional feeders).
To remove or clear feeder highlighting, click to select the feeder then choose
Unhighlight or press
F to toggle highlighting of the selected conductor. You can also clear highlighting from the Highlighting indicator displayed in the top-right of the Map or from the
Clear Highlighting option of Feeder Highlights. See
Feeder Focus in CNV Mode for more information on CNV's common feeder focus functionality available in the top right panel.
Edge Virtual Power Plants on the Map
The Flex Operations Map displays an eVPP while its direct anchor feature is loaded. Select a supported electrical branch and choose Create edgeVPP... from the selection-Action menu to create an eVPP at that anchor. Select an existing eVPP on the Map to access Edit edgeVPP... and Delete edgeVPP... from the selection's Action menu.
For information about creating, scheduling, approving, and managing eVPPs, see
Creating and Managing Edge Virtual Power Plants.
Only
Map eVPPs have map symbols and support the
Show on Map action.
Control Zone eVPPs are created and managed in the
Virtual Power Plants (eVPP) tool and are identified by their control zone rather than a map anchor. See
