Understanding the Substation Alarm Overview
The Substation Alarm Overview provides a graphical view of SCADA alarms and measurements for a selected substation.
To open the Substation Alarm Overview, select a device on the Map and then select Substation Alarm Overview from the Selection Panel. You can also open the tool from the Workspace Tool Selector when your user type has the required permission.
Use the Search field to select a substation. To return to the Map, select Position for a device or the selected substation. The Map then positions on the relevant network view.
Hover over an item in the overview to display its tooltip. Tooltips can show the device type, device name, device group, measurement name and value, RTI alias, and NMS and SCADA quality information.
From the View menu, you can show general alarms in the overview, in the banner, or in both locations. When general alarms are shown in the banner, you can choose to show only active abnormal alarms.
If your permissions allow layout editing, select Enter Edit Mode to rearrange overview items. Users with personal-edit permission save their layout only for themselves. Users with global-edit permission can save the layout for all users. Use Save to keep changes or Cancel to discard them. While editing you can also undo/redo changes and revert to the default layout.
