Managing Device Documents in Flex Operations
Viewing Document and Device Associations
Select a device on the Map, then select Device Documents from the Selection Panel. The tool contains Associated Documents, Available Documents, and Associated Devices tables. Associated Documents is populated for the selected device. Associated Devices is populated when you select a document in another table.
Opening Documents Associated with a Device
To open a document from Device Documents, double-click it, or select it and then select View Document from the corresponding table toolbar. From the Map, select the document and then select View Document from the Selection Panel.
Associating Documents with a Device
1. Select the device, then select Device Documents from the Selection Panel.
2. Select one or more documents in Available Documents, then select Associate from the table toolbar.
3. Confirm the association when prompted.
Unassociating Documents from a Device
To remove document associations for a device:
2. Select one or more documents in Associated Documents, then select Unassociate from the table toolbar.
3. Confirm the removal when prompted.
To remove device associations for a document:
1. Select Device Documents after selecting any device.
2. Select the document in Available Documents or Associated Documents.
3. Select one or more devices in Associated Devices, then select Unassociate from the table toolbar. To remove all device associations, select Unassociate All.
4. Confirm the removal when prompted.
Associating a Document with Multiple Devices
1. Select at least two devices on the Map, then select Associate Document in the upper-left corner of the Selection Results panel.
2. Select the document to associate with the selected devices, then select Associate.
