DMS Status | Meaning | Operator Action |
EVR (A/M) Event Created | The event and EVR solution have been created. | Open the EVR Report and confirm the request and solution details. |
EVR (A/M) Sheet Created | EVR created or associated a switching sheet with the event. | Open the sheet and verify the generated device blocks and values. |
EVR (A/M) Sheet Scheduled | The switching sheet is queued for its scheduled execution time. | Verify Scheduled Time, Start Date, End Date, and device blocks. |
EVR (A/M) Sheet Executing | One or more EVR switching steps are in progress. | Monitor step results and avoid conflicting device operations. |
EVR (A/M) Completed | The requested EVR execution work reached a completed state. | Verify actual setpoint, bandwidth, and low-limit values using current SCADA information. |
EVR (A/M) Execution Failed | The EVR execution did not complete normally. | Identify completed steps, verify actual device state, and determine corrective or restore work. |
Displayed Message Example | What It Confirms | Operator Review |
EVR event [event] created for solution [solution]. | An EVR event was created for the associated solution. | Verify the event and solution identifiers. |
EVR request for solution ... | The reduction percentage, device category, execution mode, and restore mode were recorded. | Confirm they match the approved request. |
EVR target calculation summary for solution ... | The report recorded counts such as ready, override, disabled, missing SCADA, and blocked. | Confirm that the reason for each abnormal or excluded result is understood. |
Started EVR switching sheet creation ... | EVR began switching-sheet generation. | Use the following messages to confirm completion. |
Completed EVR switching sheet ... | EVR completed sheet creation and recorded the sheet identifier. | Open and review the generated sheet. |
EVR switching sheet ... submitted for immediate execution. | The sheet was submitted for immediate execution. | Confirm that immediate execution was intended. |
Execution and restore messages | The report records later execution or restore activity. | Investigate alarm rows, failures, partial results, or unexpected timing. |
