Creating and Executing an Event
You can create a new event from a selected strategy. You can manually edit stages, or modify the Start Time to move the stages to start from a different time.
Once your event has included all necessary stages to accomplish your desired reduction, work through your approval process to eventually transition the state to Scheduled. Once scheduled, instructions are sent to Oracle Utilities Digital Asset Cloud Service, Oracle Utilities Analytics Insights Cloud Service, and Oracle Utilities Live Energy Connect to begin executing the event at the scheduled time. Once the event begins executing, the state will change to In Progress, and then eventually to Completed.
If you look at the event after execution, the graph will continue to display the same Before and After lines, and will also include an Actual line, representing the true load.
