Configuring Supported Services for a Head End System
The DER Aggregators tab of the DERMS DER Search tool lists the configured aggregators, or head end systems (HES). For demand response (thermostat) devices, you can specify which services each HES supports. Each service represents a group of requests sent through Live Energy Connect (LEC).
To change the supported services for an HES:
1. Open the DERMS DER Search tool and select the DER Aggregators tab.
2. Select the HES and choose Edit to open the DER Aggregator dialog box.
3. On the Details tab, use Supported Services to select the services that the HES supports. You can select more than one service or clear all selections.
4. Click OK to save the selections. Click Cancel to close the dialog box without saving your changes.
Supported Services contains the following options:
• Device Mgmt: Device enrollment queries and updates, adding and removing devices, and requests for device status used by health checks.
• Event Mgmt: Creating and canceling demand response events.
• Group Mgmt: Synchronizing demand response device groups with the HES.
• Event Reporting: Requesting demand response event outcome reports.
Edge DERMS skips the LEC operations associated with an unselected service and continues processing as though those operations succeeded. For skipped operations that normally return data, such as device status or event reporting requests, no data is returned. A successful local operation therefore does not mean that a request was sent to the HES. Clearing all selections disables these four groups of LEC operations for that HES.
The DER Aggregators table also provides a Supported Services column showing the saved selections. This column is hidden by default.
Note: The migration that introduces Supported Services does not assign services to existing HES entries. Configure the appropriate services for each existing HES after that upgrade.
