Bill Segment Fields
A bill typically contains one bill segment for every active service agreement linked to its account. A bill segment is a portion of a bill that corresponds to one or more line items in a bill. Line items could be taxes, usage charges, and other fees.
It is expected that for consecutive bills, there will be no gaps between the bill_segment_end_date of the first bill segment and the bill_segment_start_date of the next bill's segment.
For example, if the first bill's segment had a bill_segment_end_date of 2019-01-01 00:00:00, then the next bill's corresponding segment would be expected to have a bill_segment_start_date of 2019-01-01 00:00:00 as well.
Field Description
bill_id
The primary utility identifier of a bill. This is used to disambiguate bills.
Type: VARCHAR(40)
Can Be Empty?: No. Primary Key.
Note: This field is not required if you are sending your billing data in a single file to Oracle Utilities. See Billing Data File Specifications for more information.
bill_segment_id
The unique identifier of the bill segment in the source system.
Type: VARCHAR(40)
service_agreement_id
The utility’s service agreement identifier. This field corresponds to a service agreement in the Oracle Utilities Customer Care and Billing data model. See Service Agreement Fields for more detail.
Type: VARCHAR(40)
Can Be Empty?: No.
bill_segment_start_datetime
The start of the period of time covered by the bill segment’s charges. The bill period is inclusive of this datetime value.
Type: DATETIME. See Date and Time Handling for details.
Can Be Empty?: No.
bill_segment_end_datetime
The end of the period of time covered by the bill segment’s charges. The bill period is exclusive of this datetime value.
Can Be Empty?: No.
usage_period_start_datetime
The start date used by Oracle Utilities Meter Data Management to determine the correct interval data to process for the bill segment. The usage period is inclusive of this datetime value. It is typically a day behind the bill_segment_start_datetime (but could also be the same or different by more days, depending on your particular setup).
Can Be Empty?: Yes.
usage_period_end_datetime
The end date used by Oracle Utilities Meter Data Management to determine the correct interval data to process for the bill segment. The usage period is exclusive of this datetime value. It is typically a day behind the bill_segment_end_datetime (but could also be the same or different by more days, depending on your particular setup).
Can Be Empty?: Yes.
estimated
A Boolean value to indicate whether or not this value was estimated.
Type: BOOLEAN. See Supported Boolean Formats for more information.
Can Be Empty?: Yes.
closing
A Boolean value to indicate whether this is the final bill segment for the service agreement (that is, the service agreement has been stopped and this is the final bill segment).
Allowed Values:
  • Y
    Value indicating the final bill segment.
  • N
    (Default) Value indicating that this is not the final bill segment.
Can Be Empty?: Yes.
bill_segment_status
The status of the bill segment. Your Delivery Team will work with you during the launch process to confirm the status values to use.
Example Values:
  • Incomplete
    Bill segments are initially created in the Incomplete state since they do not have bill lines.
  • Freezable
    After successful generation of a bill segment, the status of the bill segment becomes Freezable.
  • Frozen
    A bill segment may now appear on customer’s bill and cannot be changed.
  • Pending Cancel
    A new financial transaction was generated to correct the bill segment.
  • Canceled
Note: The Incomplete, Freezable, and Pending Cancel statuses are not expected to appear in Oracle Utilities DataConnect extracts. The DataConnect tool only extracts bills that are complete.
Type: VARCHAR(20)
Can Be Empty?: No.
bill_cycle_code
The bill cycle of the bill segment's bill. This information is only populated on bills when they are generated on-schedule by the batch billing background process.
Example Values: M01,M02
Type: VARCHAR(20)
Can Be Empty?: Yes, but preferred to not be empty.
bill_cycle_description
A description of the bill cycle.
Example Values: Monthly bill cycle - day 1, Monthly bill cycle - day 2
Type: VARCHAR(255)
Can Be Empty?: Yes.
current_amount
The amount owed on a service agreement for the bill period.
Type: DECIMAL(15,2). See Supported Decimal Formats for details.
Can Be Empty?: No.
outstanding_amount
The aggregate total outstanding amount for the service agreement. This is likely the same as the current amount unless there is a budget billing arrangement. Note that budget billing arrangements are made per Service Agreement, and then rolled up to the bill/account level.
Can Be Empty?: No.
master_bill_segment_id
The identifier of the master service agreement’s bill segment. The master_bill_segment_id must reference another bill_segment_id that was previously sent, or is part of the same file that this bill segment was sent in.
Type: VARCHAR(40)
Can Be Empty?: Yes.
bill_segment_updated_at
The date at which the record was updated in the source system. If left blank, the field does not store any data.
Can Be Empty?: Yes.
