Getting Started with Flat File Data Transfer
Flat file data transfer is used when a utility provides Oracle Utilities Opower with data extracts from its source systems. This method is typically reserved for special cases where modern ingress options (such as OCI GoldenGate, Delta Sharing, or API-based ingress) are not feasible.
To use flat file transfer, you must generate data files that conform to Oracle Utilities Opower data transfer standards, including the required entities, fields, formats, and delivery schedules for the products being implemented. Oracle Utilities works with you to identify the required data standards, review sample files, validate historical data, and approve ongoing incremental files before production use. The required files and delivery frequency vary based on the Oracle Utilities Opower products and customer experiences included in the program.
