Weather Insights Module
The Weather Insight module educates customers on how changes in temperature can affect their energy use. It also provides a comparison between the current month's average temperature and the average temperature from the same month of the previous year.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Options | Input Value |
Heading The default heading of the module varies depending on the state. These are the default headings by state:
Optional Choose one of the following:
Weather Insight Statement The default weather insight statement varies depending on the state. These are the default headings by state:
Temperature Threshold The weather insight identifies weather as potentially impacting a customer's energy use when the temperature difference for the same time last year is greater than a defined threshold. Default: 8 degrees Fahrenheit |
