Adding Flow Variable Container to a Flow
To add a flow variable container to a flow:
  1. Select and right-click the flow name in the Oracle Utilities Testing Accelerator flows tree structure.
  2. Click Create/Update Flow Structure.
  3. Click Add Global Variable Container.
  4. Right-click the variable container in the flow tree structure and select Edit Test Data.
  5. Define a flow variable name in the Output Variable Name field.
  6. Define the variable value in the Value field.
  7. Add more rows and enter the variables.
  8. Click Save to save the updates.
These variables can be used as test data in the subsequent components in the flow.
