Adding and Removing Flow Sets in a Test Plan
To add a flow set to a test plan:
- Login to the application.
- Navigate to the Test Planning menu.
- Search for the test plan using the search filters.
- Select the test plan to be edited.
- Click Edit next to the Test Plan Definition.
Alternatively, click Add Flow Set.
- In the Edit Test Plan screen, select the flow set to be added to the test plan and drag and drop it into the Test Plan Definition column.
Make sure to select the flow set before it is dragged into the Test Plan Definition column. Use the Flow Sets filter to find one or more flow sets based on the flow set name.
- Click Save to save the test plan definition.
To remove a flow set from a test plan:
- Select the flow set and click X next to it in the Test Plan Definition column.
