Reordering Components in a Flow
Note that a flow needs to be “In progress” for components to be re-ordered. You cannot re-order components in a flow that is locked by another user.
To change the sequence of components in a scenario:
  1. Login to the application.
  2. Navigate to the Flows menu.
  3. In the left pane, right-click the flow for which components have to be reordered.
    Use the Search Component field on the top of the approved component tree to find the components you need. The available components are listed similar to a type ahead search, with the product and module names under which the component is available. Select the appropriate component from the prompted results and the corresponding component is highlighted in the approved component tree.
  4. Select Create/update Flow Structure.
    Reorder the components in any of the following ways:
    • By drag-and-drop method
    • Moving the components to a desired location using menu:
  5. Right-click the component to be moved and select Move Component.
    Move the selected component in any of the following ways:
    • Right-click another component in the flow and choose Paste Component Above.
    • Right-click another component in the flow and choose Paste Component Below.
    • Right-click a scenario in the flow and choose Paste Component Inside. This will move the selected component to the first position in the scenario.
  6. After reordering the components, click Save to save the modified flow.
The popup closes and the flow tree is refreshed to reflect the correct order of components.
