Running a Test Plan
To run a test plan:
- Login to the application.
- Navigate to the Test Planning menu.
- Search for the test plan using the search filters.
- Select the test plan to be run (make sure that the test plan is in “Active” state).
- Click Run in the Test Plan Definition section on the Test Plan page.
- Select the Flow Configuration Set and the User Configuration Set. Click Confirm.
The test plan run page is displayed showing the state of the flow set runs for the test plan.
- To view detailed results of the flow set runs, click the corresponding flow set on the Test Plan Results page.
