Day by Day and Hourly Breakdown Module
The Day By Day and Hourly Breakdowns module displays these breakdowns one after the other. Refer to each section to learn about each breakdown.
Design - Day by Day Breakdown
This image shows an example of the module.
Configuration Options - Day by Day Breakdown
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
Title and Subtitle
The title indicates the purpose of the graph. The subtitle indicates the day when energy usage or cost was the highest.
Default: Varies by fuel type. See User Experience Variations below for details.
Optional
Choose one of the following:
  • Use the default title and subtitle.
  • Work with your Delivery Team to specify a different title and subtitle.
Bar Colors
Bar colors in the graph can match the utility’s color palette. Both the peak bar color and the non-peak bar color can be changed.
Default: The colors in the example represent the default colors.
Required
  • Use the default colors.
  • Work with your Delivery Team to specify other colors.
Display Cost Information (not depicted)
If a customer's rates are modeled, the cost per day can be displayed below each bar in the graph.
Default: Display cost information if it is available.
Optional
  • Use the default (display the cost information if it is available).
  • Hide the cost information.
User Experience Variations - Day by Day Breakdown
The user experience varies for customers depending upon their service types, available data, costs, and locale. Note that the following list indicates the primary user experience variations, not all possible variations.
Title
  • “Your electricity use this week”
  • “Your gas use this week”
Subtitle
  • “You used the most on <day>”
Gas-Only
For gas-only customers, the electricity unit “kWh” is replaced by “therms” or "CCFs" (whichever unit of measure is appropriate for the utility), and the word "electricity" is replaced by "gas".
Dual Fuel
Dual fuel customers see two separate Day-by-Day Breakdown modules, one for electricity use and one for gas. The heading above each graph specifies the fuel type.
Rates Modeled
If rates are modeled and the utility has opted to display cost information in this module, then cost information is displayed above each bar in the graph to indicate the cost of energy for that day.
Solar Customers, Negative Values
For customers on solar net metering rate plans, positive and negative net energy use values can be displayed in the Day by Day Breakdown graph. This can include bars that are displayed below the graph axis to represent negative values as shown in the example below. Be aware the support for negative value display must be configured, which is discussed as part of the global configurations in the Weekly Engagement Reports Configuration Guide.
An example of the day by day breakdown graph that includes negative energy use for applicable days of the week and are represented as negative in the bar graph.
In the event of a net-zero reading day, the "bar" is plotted directly on the axis line of the graph. See Saturday in the above image for an example.
Design - Hourly Breakdown
Configuration Options - Hourly Breakdown
Title
The title indicates the general time period during which the customer used the most energy.
Default: Varies by time of day. See User Experience Variations below for details.
Optional
  • Use the default titles.
  • Work with your Delivery Team to specify different titles.
Line Colors
Colors in the graph line graph and in the shading below the line can match the utility’s color palette.
Required
  • Work with your Delivery Team to specify different colors.
Call-to-Action URL
The call-to-action URL (“See more electricity trends”) directs the user to another web feature where this more detailed information about their energy use over time.
Default: The link points to the Energy Management Data Browser.
Optional
  • Use the default.
  • Work with your Delivery Team to discuss pointing the link to a different feature or web page.
User Experience Variations - Hourly Breakdown
Gas-Only
Dual Fuel
Dual fuel customers see two separate Hourly Breakdown modules, one for electricity use and one for gas. The button below each graph specifies the fuel type.
Titles
The title varies by the time period during which the customer used the most energy.
  • “On [date], you used the most in the morning.”
  • “On [date], you used the most in the afternoon.”
  • “On [date], you used the most in the evening.”
  • “On [date], you used the most at night.”
For customers on solar net metering rate plans, positive and negative net energy use values can be displayed in the Hourly Breakdown graph. This can include bars that are displayed below the graph axis to represent negative values as shown in the example below. Be aware the support for negative value display must be configured, which is discussed as part of the global configurations in the Weekly Engagement Reports Configuration Guide.
An example of the hourly breakdown graph that includes negative energy use for applicable hours of the day and are represented as negative in the bar graph.
In the event of a net-zero reading hour, the "bar" is plotted directly on the axis line of the graph. See 5pm in the above image for an example.
