E AMC Keystore Migration from JKS to PKCS12
Java Key Store (JKS), a widely used key store implementation is being phased out in favor of Personal Information Exchange Syntax Standard (PKCS12), which is a more modern and widely supported key store format. It provides several advantages, including enhanced security, interoperability, and compatibility with modern applications and tools. Oracle recommends migration of keys and certificates from JKS to PKCS12.
This section details the steps involved in manual migration from JKS keystore to PKCS12.
Prerequisite
JDK 8u152 or above is required to run the Java keytool.
Migration Steps
Follow these steps to migrate from JKS keystore to PKCS12 keystore.
- Go to AMC agent installation location and access
conffolder.$cd ~/Java_AMC/conf - Note down the following properties from
AMCKeystore.propertiesfile:- agent.keystore.password:<password>
- signing.keystore.password:<password>
- To migrate AMC keystore to PKCS12 standard:
- Migrate
AMCAgent.jksto PKCS12 using the following commands:$ sudo keytool -importkeystore -srckeystore AMCAgent.jks -destkeystore AMCAgent.jks -srcstoretype JKS -deststoretype PKCS12 -deststorepass <agent.keystore.password>$ Enter source keystore password: <agent.keystore.password>Expected result (ignore any warning message) :
Entry for alias **** successfully imported. Import command completed: 1 entries successfully imported, 0 entries failed or cancelled - Migrate
AMCSigning.jksto PKCS12 using the following commands:$ sudo keytool -importkeystore -srckeystore AMCSigning.jks -destkeystore AMCSigning.jks -srcstoretype JKS -deststoretype PKCS12 -deststorepass <signing.keystore.password>$ Enter source keystore password: <signing.keystore.password>Expected result (ignore any warning message) :
- Migrate
- Restart the agent.
$ sudo ./AMCAgent.sh -restart - Verify if the agent is working.
- If the agent is working as expected, remove the
tempkeystore file (optional):$ sudo rm-fAMCAgent.jks.old $ sudo rm-fAMCSigning.jks.old $ sudo rm-fAMCAgent.jks.tmp #If available $ sudo rm-fAMCSigning.jks.tmp #If available - If the agent is not working as expected, run the following commands and repeat steps 3 to 5:
$ sudo mv AMCAgent.jks AMCAgent.jks.tmp $ sudo mv AMCSigning.jks AMCSigning.jks.tmp $ sudo mv AMCAgent.jks.old AMCAgent.jks $ sudo mv AMCSigning.jks.old AMCSigning.jks
