Managing Job Canvas with Right-Click Menu
There are further options available when creating or editing a job, accessible via the right-click menu.
Select a task on the canvas and right click to display the menu. The options are as follows:
Enabled - If the selected task is enabled, there will be a checkmark next to this option. Select or deselected as required.
Configure Task... - This option displays the Configure Task dialog. For further details, see the Running Jobs Using Data Interfaces topic.
Delete - Deletes the selected task.
Open - Opens the selected task in the Process Canvas.
Cut, Copy, Paste - These options are simply used to cut, copy and paste tasks as required on the Job Canvas.
