27 Using the JavaScript, Python, and Go gRPC Clients
To connect to Coherence from other clients which use gRPC, such as JavaScript, Python, and Go, you should refer to the relevant open source repositories for details and examples.
Use a released client version and pin its dependency/lock file. Consult that client release documentation for runtime prerequisites, TLS/authentication options, JSON/POF support and implemented features. Test reconnects, listener cleanup, deadlines and shutdown with the selected proxy version; do not assume Java client API parity or copy a development-branch example into a released deployment. Server model/executable trust requirements still apply.
Parent topic: Getting Started with gRPC
