Best Practices for Switches and Zoning
Follow these best practices for switches and zoning in your environment:
  • FC-SW configurations: check with the switch manufacturer for optimal configuration recommendations, including zoning.
  • Note that FC-AL is not supported. Use FC-P2P instead.
  • Use single initiator hard zoning to do the following:
    • Avoid Registered State Change Notification (RSCN) storms.
    • Shield devices from indiscriminate SCSI inquiries.
    • Provide security by avoiding inappropriate access.
  • Use meaningful names for zones, and document the entire configuration.
  • Use FCP-2 (also called FC-TAPE or FCP Error Recovery) only with tape and/or sequential devices. While FCP-2 might not cause problems for hard disk drives (HDDs), FCP-2 is a sequence-level error recovery mechanism that is irrelevant to HDDs.
  • If using FC tape backups, place tape ports and backup servers on the same FC switch to avoid tying up inter-switch links (ISLs).
  • Storage Area Network (SAN) switches can be a major source of disruption if you do not take extreme care with respect to configuration. Do not perform updates to switch operating systems and/or firmware, or enable new features on SAN switches, until you have first tried the updated switches in a test configuration. The HBA might not support newer switch features, and switch operating system and/or firmware updates might require changes to, and/or restoration of, switch configuration settings.
