Best Practices for Switches and Zoning
Follow these best practices for switches and zoning in your environment:
FC-SW configurations: check with the switch manufacturer for optimal configuration recommendations, including zoning.
Note that FC-AL is not supported at 16 Gb/s or faster. Use FC-P2P instead. However, if you manually change the HBA to the 8Gb/s or lower data rate, Fibre Channel arbitrated loop is supported, but only at the 8 Gb/s date speed rate.
Use single initiator hard zoning to do the following:
Avoid Registered State Change Notification (RSCN) storms.
Shield devices from indiscriminate SCSI inquiries.
Provide security by avoiding inappropriate access.
Use meaningful names for zones, and document the entire configuration.
Use FCP-2 (also called FC-TAPE or FCP Error Recovery) only with tape and/or sequential devices. While FCP-2 might not cause problems for hard disk drives (HDDs), FCP-2 is a sequence-level error recovery mechanism that is irrelevant to HDDs.
If using FC tape backups, place tape ports and backup servers on the same FC switch to avoid tying up inter-switch links (ISLs).
Storage Area Network (SAN) switches can be a major source of disruption if you do not take extreme care with respect to configuration. Do not perform updates to switch operating systems and/or firmware, or enable new features on SAN switches, until you have first tried the updated switches in a test configuration. The HBA might not support newer switch features, and switch operating system and/or firmware updates might require changes to, and/or restoration of, switch configuration settings.
