Supported Speeds Field Value Does Not Display 32 Gb As a Supported Speed
Bug ID: 25904735
Issue:
When issuing the fcinfo hba-port command from a virtual function
domain, the output for the HBA does not display 32 Gb as a supported speed, even though 32 Gb
is a supported speed. The following example shows values that might be displayed.
$fcinfo hba-port
HBA Port WWN: 31000024ff19a37c
Port Mode: Initiator
Port ID: 0
OS Device Name: /dev/cfg/c2
Manufacturer: QLogic Corp.
Model: 7335902
Supported Speeds: 4Gb 8Gb 16Gb
Current Speed: 16GbHowever, if you issue the fcinfo hba-port command from a physical
function domain, the accurate Supported Speeds values are displayed.
$fcinfo hba-port ... Supported Speeds: 8Gb 16Gb 32Gb ...
Workaround:
Check for the availability of a patch to address this issue. You can obtain patches at: Oracle Driver Download
Until a patch is available, do not issue the fcinfo hba-port command
from inside a virtual function domain. Instead, issue the command from a physical
domain.
