Zone Does Not Boot if pkg:/system/resource-mgmt/resource-caps Is Not Installed and capped-memory Is Configured (15740089)
Problem Summary: If the package pkg:/system/resource-mgmt/resource-caps is not installed and a zone is configured with the capped-memory resource control as part of the configuration, the zone boot fails. Output is similar to the following:
zone 'zone-1': enabling system/rcap service failed: entity not found zoneadm: zone 'zone-1': call to zoneadmd failed
Workaround: Install the pkg:/system/resource-mgmt/resource-caps package into the global zone. Once the resource-caps package is installed, the zone can boot.
