Log In to Oracle ILOM Using a Remote Ethernet Connection
You can log in to the Oracle ILOM web interface or CLI remotely using one of the network ports on the server.
You need to know the IP address or host name of the SP to log in to Oracle ILOM remotely. If you do not know the IP address of the SP, see Troubleshooting Oracle ILOM.
To enable first-time login and access to Oracle ILOM, a default
Administrator account and its password are provided with the system. To
build a secure environment and enforce user authentication and authorization
in Oracle ILOM after your initial login, change the default password
(changeme
) for the default Administrator account
(root
). If this default Administrator account was
changed, contact your system administrator for an Oracle ILOM user account
with Administrator privileges.
For information about how to change the root password, refer to the Oracle Integrated Light Out Manager (ILOM) Documentation library at https://www.oracle.com/goto/ilom/docs .
To prevent unauthorized access to Oracle ILOM, create user accounts for each user. For details, refer to the Oracle Integrated Lights Out Manager (ILOM) Documentation Library at https://www.oracle.com/goto/ilom/docs .
To improve response times, disable the web browser proxy server (if one is enabled).
