- Oracle X9 Series Servers Administration Guide
- Backing Up, Restoring, and Resetting Firmware Default Values
- Resetting Oracle ILOM SP to Default Values
- Reset SP to Default Values (Oracle ILOM)
- Ensure that you have Admin (a) role privileges in Oracle ILOM.
To reset the Oracle ILOM firmware to default settings in the Oracle ILOM
web interface:
- Log in to the Oracle ILOM web interface.
- In the navigation pane, click ILOM Administration → Configuration Management, and then click the Reset Defaults tab.
- In the Reset Defaults drop-down list, select Factory.
- Click Reset Defaults.
To reset the SP to default settings in the Oracle ILOM command-line
interface (CLI):
- Log in to the Oracle ILOM CLI.
- Type: set /SP reset_to_defaults=factory.
For details, refer to Reset the Oracle ILOM Configuration to Factory Defaults, Oracle ILOM Administrator's Guide for Configuration and Maintenance, Firmware Release 5.0 at Systems Management Documentation.
