Using Oracle Hardware Management Pack
Before using Oracle Hardware Management Pack, you must install it (unless you are running Solaris 11.2 or newer), and you must install an operating system. After that, you can run Oracle Hardware Management Pack commands from the operating system command line, and you can configure and use the management agents.
For installation instructions, see:
Oracle Hardware Management Pack Installation Guide at Systems Management Documentation
To get started, see the following procedures:
