Power Down the Server for Immediate Shutdown Using the Oracle ILOM Web Interface
Caution:
An immediate power-off might corrupt system data, therefore, use this procedure to power down the server only after attempting the graceful power down procedure.
  1. Log in to the Oracle ILOM web interface using an Administrator account.
    The Oracle ILOM web interface System Information → Summary Information page appears.
  2. In the left pane, click Host Management → Power Control, and click Immediate Power Off in the Select Action list.
  3. Click Save, and then click OK.
    The server powers down immediately to Standby power mode.
  4. Disconnect the power and data cables from the server.
    See Disconnect Cables From the Server.
    Caution:
    When you power down the server using Oracle ILOM, the server enters Standby power mode. Power is still directed to the service processor and power supply fans. To completely power off the server, you must disconnect the power cords from the power supplies.
