Validate Connectivity Between Exadata Systems
Ensure that you can connect to both the primary Oracle Exadata Database Machine on-premises and the standby Oracle Database Exadata Cloud Service in the cloud using a key.
Connect to the Primary Oracle Exadata Database Machine
Connect to the primary, on-premises Oracle Exadata Database Machine.
Generate a key to use to connect your on-premises and cloud instances. In
this example, the key is cluster.key.
Connect to the Standby Oracle Database Exadata Cloud Service
Connect to the standby Oracle Database Exadata Cloud Service in the cloud.
