Use Remote Synchronous Block Replication on Oracle Cloud Infrastructure
Provide fault tolerance of block volumes using remote synchronous block replication.
Typical challenges for many enterprises include: applications running on top of a database, applications accessing underlying block devices, and a business requirement for zero delays in services.
Take payment processing companies, for example. As a delay in payment processing negatively impacts reputation and brand name in the eyes of their customers, they need to have high-availability technology to provide true fault tolerance (that is, zero service interruptions in case of a single-component failure).
Architecture
This architecture implements a highly available block device on Oracle Cloud Infrastructure (OCI), fully tolerant to a failure at the level of business application. Use this architecture for performance-sensitive applications that require continuity at the same time.
This architecture will provide a single entity, iSCSI block device to users. This device will be always available, regardless of single-component failures. Any other architecture components will be hidden from users. The architecture is fully automated in case of a failure or switchover. The only effect users will notice in case of failure or switchover will be performance degradation of the iSCSI device by around 50% for one or two seconds.
Implementation of a single, always-available block devices requires the following.
- Three compute instances, virtual machines, or bare metal (BM). The latter may be preferable as they have stable performance.
- Two VCNs: one public, one private.
- Two block volumes of your target always-available device.
- (Recommended) Have the block volumes at least 10 VPU. You may want to consider an even higher level of IOPS, depending on the aggressiveness of your I/O throughput, and the distance between the mirrored hosts (and block volumes).
Therefore, the cost of implementing an always-available block device is three times the cost of the compute instance plus two times the cost of the device itself.
The following diagram illustrates this reference architecture.
remote-synchronous-block-replication-diagram-oracle.zip
The architecture has the following components:
- Distributed Replicated Block Device
Distributed Replicated Block Device (DRBD) is a Linux kernel driver that maintains network connection between two block devices on remote Linux instances, and replicates I/O operations from the source instance to the destination instance.
- Pacemaker
Pacemaker is an open-source high-availability cluster resource manager, commonly used in Linux environments. It ensures that applications, services, or resources run continuously with minimal downtime by detecting failures and automatically restarting or relocating services on other nodes in a cluster.
- Corosync
Corosync is an open source software product that extends Pacemaker with semantics of restoration in the case of split brain.
- iSCSI initiator and target
iSCSI is a client and server software component that provides an SCSI device over a network.
Recommendations
- VCN
When you create a VCN, determine the number of CIDR blocks required and the size of each block based on the number of resources that you plan to attach to subnets in the VCN. Use CIDR blocks that are within the standard private IP address space.
Select CIDR blocks that don't overlap with any other network (in Oracle Cloud Infrastructure, your on-premises data center, or another cloud provider) to which you intend to set up private connections.
After you create a VCN, you can change, add, and remove its CIDR blocks.
When you design the subnets, consider your traffic flow and security requirements. Attach all the resources within a specific tier or role to the same subnet, which can serve as a security boundary.
- Cloud Guard
Clone and customize the default recipes provided by Oracle to create custom detector and responder recipes. These recipes enable you to specify what type of security violations generate a warning and what actions are allowed to be performed on them. For example, you might want to detect Object Storage buckets that have visibility set to public.
Apply Cloud Guard at the tenancy level to cover the broadest scope and to reduce the administrative burden of maintaining multiple configurations.
You can also use the Managed List feature to apply certain configurations to detectors.
- Security Zones
For resources that require maximum security, Oracle recommends that you use security zones. A security zone is a compartment associated with an Oracle-defined recipe of security policies that are based on best practices. For example, the resources in a security zone must not be accessible from the public internet and they must be encrypted using customer-managed keys. When you create and update resources in a security zone, Oracle Cloud Infrastructure validates the operations against the policies in the security-zone recipe, and denies operations that violate any of the policies.
- Network security groups (NSGs)
You can use NSGs to define a set of ingress and egress rules that apply to specific VNICs. We recommend using NSGs rather than security lists, because NSGs enable you to separate the VCN's subnet architecture from the security requirements of your application.
- Load balancer bandwidth
While creating the load balancer, you can either select a predefined shape that provides a fixed bandwidth, or specify a custom (flexible) shape where you set a bandwidth range and let the service scale the bandwidth automatically based on traffic patterns. With either approach, you can change the shape at any time after creating the load balancer.
Considerations
Consider the following when deploying this reference architecture.
- Performance
You should plan two times N of nominal IOPS on your always-available device in order to provide N IOPS to your users. This is caused by the fact that half of the performance is spent on real-time mirroring.
- Security
We strongly recommend isolating implementation details by splitting the solution to public and private networks.
- Availability
We recommend implementing always-available device as iSCSI for this technology is OS-agnostic, so users can enjoy true fault tolerance whether they run Linux or Windows on their machines.
All the software components of the solution are publicly available as open-source products. In particular, the DRBD driver is an integral component of the vanilla Linux kernel and is available in any Linux distro.
