Appliance Problems and Solutions
These are the common problems experienced with the appliance and possible solutions.
Table 3-1 Appliance Problems and Solutions
| Problem | Solution |
OKM Cluster does not appear to be Up after being added as an instance to be monitored. |
An error could have been made when setting up the instance for monitoring, or a change in configuration on the KMA could be affecting communication. Check the following:
This may be an indication that the timeout setting for the plugin could be increased, especially if the target goes down intermittently. To change the timeouts for the plugin, follow these steps:
OKM Cluster is Up, but some items are missing from Summary and/or Performance pages. |
You must upload metrics before they can be displayed in the Summary or Performance pages. Metrics can take up to an entire collection cycle (up to 1 day for some metrics) to be uploaded. If the KMA is not responding consistently, this can affect metric collection. See the previous Solution for setting the timeouts for the plugin. Metrics and information about system values are collected in varying intervals. If you have a need for real-time information, refer to the Oracle Key Manager Management GUI. |
A Metric Detail is not showing a change made on the system. |
Metrics and information about system values are collected in varying intervals. In the worst case, a metric could be as much as 24 hours out of sync with a KMA. If you have a need for real-time information, refer to the Oracle Key Manager Management GUI. |
A certificate exported for the OKM Operator is not being accepted. |
If this certificate was exported using a 3.0.x Solaris Oracle Key Manager Management GUI, the size of the certificate file is 0. This certificate must be exported using an older GUI, or must be exported from a Windows Oracle Key Manager Management GUI. |
