Configuring SMB Project and Share (BUI)
Use the following procedure to configure a SMB project and share.
- From the Shares menu, select Shares.
Create a project.
- On the Shares screen, click the panel open icon
to expand the Projects panel.
- Click the add icon
to add a new project.
- Specify the project name, and click APPLY.
- Select the new project from the Projects panel.
- Click the add item icon
to add a filesystem.
- Click the edit icon
for the filesystem.
- Click the General tab, and deselect the Inherit from project check box.
- Choose a mountpoint under /export, even though SMB shares are accessed by resource name, and click APPLY.
- Click the Protocols tab for the project, and set the SMB resource name to on.
- Enable sharesmb and share-level ACL for the project.
- Click APPLY to activate the configuration.
