Disabling Replication Compression (BUI)
You can disable compression when you create or edit a replication action. By default, all replication streams are compressed before being sent over the network. For more information, see Compressed Replication.
- Source appliance: From the Shares menu, select Projects, and double-click on the project you want to edit.
- Click the Replication tab.
- Click the edit icon
. - Click Disable compression, and click Apply.
Related Topics
