- Oracle ZFS Storage Appliance Administration Guide, Release OS8.8.x
- Shadow Migration
- Monitoring Migration Progress
- Monitoring Migration Progress and Errors (CLI)
Use the following procedure to monitor migration progress and errors.
- Go to a filesystem with shadow migration source, and enter
shadow
, and then enterlist
.hostname:shares default/file_sys1> shadow hostname:shares default/file_sys1 shadow> list Properties: source = nfs://zfs0000-15/sm/errors transferred = (unset) remaining = 1.37G elapsed = 0h3m errors = 23 complete = true time = (unset) Children: errors => Shadow Migration Errors hostname:shares default/file_sys1 shadow>
If there is no shadow migration source defined (shadow=none
), then theshadow
command is invalid for the filesystem:hostname:shares default/xyz_1> shadow error: invalid command "shadow"
- To view shadow migration errors, enter child node
errors
, and enterhelp
to view a list of subcommands.hostname:shares default/file_sys1 shadow> errors hostname:shares default/file_sys1 shadow errors> help Subcommands that are valid in this context: help [topic] => Get context-sensitive help. If [topic] is specified, it must be one of "builtins", "commands", "general", "help" or "script". show => Show information pertinent to the current context done => Finish operating on "errors" select [entry] => Select the specified entry to get its properties, set its properties, or run a subcommand list => Lists up to the first 100 errors. The "-a" option may be used to list all the errors if there are more that 100 errors. The "-number" option may be used to list the first (number) of errors. Format: list -a or list -xx
- Enter
show
to view individual migration errors in the current context.hostname:shares default/file_sys1 shadow errors> show Errors: PATH REASON ak-2013-dev-on-clone.tar.gz Permission denied test_dir/CREDITS.html Permission denied test_dir/CREDITS_ja.html Permission denied test_dir/CREDITS_pt_BR.html Permission denied test_dir/CREDITS_zh_CN.html Permission denied test_dir/DISTRIBUTION.txt Permission denied test_dir/LEGALNOTICE.txt Permission denied test_dir/LICENSE.txt Permission denied test_dir/README.html Permission denied test_dir/README_ja.html Permission denied test_dir/README_pt_BR.html Permission denied test_dir/README_zh_CN.html Permission denied test_dir/THIRDPARTYLICENSE.txt Permission denied test_dir/bin Permission denied test_dir/cnd2 Permission denied test_dir/etc Permission denied test_dir/gsf1 Permission denied test_dir/ide10 Permission denied test_dir/modCluster.properties Permission denied test_dir/nb6.5 Permission denied test_dir/forms.css Permission denied test_dir/platform9 Permission denied test_dir/websvccommon1 Permission denied
- To view an individual error, enter the
select
command and an individual error name. Then entershow
.To view individual error properties, use the
get
command.hostname:shares default/file_sys1 shadow errors> select test_dir/nb6.5 hostname:shares default/file_sys1 shadow errors test_dir/nb6.5> show Properties: path = test_dir/nb6.5 reason = Permission denied hostname:shares default/file_sys1 shadow errors test_dir/nb6.5> get path path = test_dir/nb6.5 hostname:shares default/file_sys1 shadow errors test_dir/nb6.5> get reason reason = Permission denied hostname:shares default/file_sys1 shadow errors test_dir/nb6.5> done hostname:shares default/file_sys1 shadow errors>
