Project Properties
In the CLI, use the get command to see a list of all properties.
Use the list command to list all children.
The following table shows Create Project properties.
Table 4-3 Create Project Properties
| BUI Name | CLI Name | Property Type | Description |
Name |
Static |
Defines the name of the project. |
Encryption |
Inherited |
Defines the encryption type. For more information see, Managing Encryption Keys. |
Inherit key |
If selected, indicates that the encryption key is inherited from the parent pool. |
Key |
Inherited |
Sets a specific encryption key that is used when the key is not inherited from the parent pool. |
Keyname |
Static |
Identifies the key. |
| File retention policy | retention.policy |
Inherited |
Sets one of the following options:
Project filesystems inherit file retention properties when the project is created, and the properties are local to the project's filesystems. Therefore, if a project is later renamed, the filesystems still retain their originally inherited file retention properties. |
| File retention on expiry policy | retention.policy.onexpiry |
Inherited | Determines behavior when file retention expires. Sets one of the following options:
| Delete expired files after | retention.period.deletegrace |
Inherited | Number of seconds/hours/days/years that automatic file deletion is delayed when the file retention on expiry policy is set to delete. Default value: 0 days.
| Allow permission changes on retained files | retention.policy.changeacl |
Inherited | Determines if a retained file's ACL/permissions can be changed. Default value is off and the file's ACL/permissions cannot be changed. When set to on, the ACL settings/permissions, other than write, can be changed on a retained file.
The following table shows General - Space Usage - Data project properties.
Table 4-4 General - Space Usage - Data Project Properties
Quota |
Space management |
Sets a limit on the amount of space that can be consumed by any particular entity. |
Reservation |
Space management |
Represents a guarantee of space that can be consumed by any particular entity. |
The following table shows General - Space Usage - Users & Groups project properties.
Table 4-5 General - Space Usage - Users & Groups Project Properties
Default user quota |
Space management |
Sets a limit on the amount of space that can be consumed by the user. |
Default group quota |
Space management |
Sets a limit on the amount of space that can be consumed by the group. |
User and group |
Specifies users and/or groups. |
Usage |
Space management |
Shows the amount of data used by users and/or groups. |
The following table shows General - Inherited Properties project properties.
Table 4-6 General - Inherited Project Properties
Mountpoint |
Inherited |
Controls the path used to export filesystems. For more information, see Mountpoint. |
Read only |
Inherited |
Controls whether the filesystem contents are read only. For more information, see Read only. |
Update access time on read |
Inherited |
Controls whether the access time for files is updated on read. For more information, see Update access time on read. |
Non-blocking mandatory locking |
inherited |
Controls whether SMB locking semantics are enforced over POSIX semantics. For more information, see Non-blocking mandatory locking. |
Data deduplication |
Inherited |
Controls whether duplicate copies of data are eliminated. For more information, see Data Deduplication. |
Data compression |
Inherited |
Controls whether data is compressed before being written to disk. For more information, see Data Compression. |
Checksum |
Inherited |
Controls the checksum used for data blocks. For more information, see Checksum. |
Cache device usage |
Inherited |
Controls whether cache devices are used for the share. For more information, see Cache device usage. |
Synchronous write bias |
Inherited |
Controls the behavior when servicing synchronous writes. For more information, see Synchronous write bias. |
Database record size |
Inherited |
Specifies a suggested block size for files in the filesystem. For more information, see Database record size. |
Additional Replication |
Inherited |
Controls number of copies stored of each block, above and beyond any redundancy of the storage pool. For more information, see Additional replication. |
Virus scan |
Inherited |
Controls whether a filesystem is scanned for viruses. For more information, see Virus scan. |
Prevent destruction |
Inherited |
Prevents shares or projects from being destroyed when set. For more information, see Prevent destruction. For preventing destruction at the storage pool level, see Destroy Prevention and Approval. |
Restrict ownership change |
Inherited |
Controls the ownership and can be turned off on a per-filesystem or per-project basis. For more information, see Restrict ownership change. |
The following table shows General - Custom Properties project properties.
Table 4-7 General - Custom Project Properties
Schema |
Custom properties can be added as needed to attach user-defined tags to projects and shares. For more information, see Schema Properties. |
The following table shows General - Default Settings - Filesystems project properties.
Table 4-8 General - Default Settings - Filesystems Project Properties
User |
Creation default |
Specifies a user ID or user name. |
Group |
Creation default |
Specifies a group ID or group name. |
Permissions |
Creation default |
Sets the default permissions for filesystem. |
The following table shows General - Default Settings - LUNs project properties.
Table 4-9 General - Default Settings - LUNs Project Properties
Volume size |
LUN only, creation default |
Shows the maximum volume size and unit of measurement. For more information, see Volume size. |
Thin provisioned |
Indicates only the amount of space physically consumed by data is used when selected. For more information, see Thin provisioned. |
Volume block size |
Creation default |
Shows the native block size for LUNs and can be set from 512 bytes to 1M; the default is 8K. For more information, see Volume block size. |
The following table shows Bandwidth project properties.
Table 4-10 Bandwidth Project Properties
Read limit |
Sets the maximum bytes per second that can be read from a share. |
Write limit |
Sets the maximum bytes per second that can written to a share. |
Effective read limit |
Read-only property that reports the lowest read limit for a share. |
Effective write limit |
Read-only property that reports the lowest write limit for a share. |
The following table shows Protocols - NFS project properties.
Exceptions to the overall sharing modes may be defined for clients or collections of clients. For more information, see NFS Protocol Share Mode Exceptions.
Table 4-11 Protocols - NFS Project Properties
NFS |
Inherited |
NFS Protocol property settings and values are described in NFS Protocol Properties. |
The following table shows Protocols - SMB project properties.
Exceptions to the overall sharing modes may be defined for clients or collections of clients. For more information, see SMB Protocol Share Mode Exceptions.
Table 4-12 Protocols - SMB Project Properties
SMB |
Inherited |
SMB Protocol property settings and values are described in SMB Protocol Properties. |
The following table shows Protocols - HTTP (Inherit from project) project properties.
Table 4-13 Protocols - HTTP (Inherit from project) Project Properties
Share mode |
Inherited |
Determines whether the share is available for reading only, for reading and
writing, or neither. In the CLI, |
The following table shows Protocols - FTP (Inherit from project) project properties.
Table 4-14 Protocols - FTP (Inherit from project) Project Properties
Share mode |
Inherited |
The following table shows Protocols - SFTP (Inherit from project) project properties.
Table 4-15 Protocols - SFTP (Inherit from project) Project Properties
Share mode |
Inherited |
The following table shows Protocols - TFTP (Inherit from project) project properties.
Table 4-16 Protocols - TFTP (Inherit from project) Project Properties
Share mode |
Inherited |
The following table shows Access project properties.
Table 4-17 Access Project Properties
ACL behavior on mode change |
Inherited |
Controls how a mode change request interacts with the existing ACL. |
ACL inheritance behavior |
Inherited |
Controls how a new file or directory inherits existing ACL settings from the parent directory. |
The following table shows Snapshots - Properties project properties.
Table 4-18 Snapshots - Properties Project Properties
.zfs/snapshot visibility |
Inherited |
Controls whether filesystem snapshots can be accessed over data protocols at |
Scheduled snapshot label |
Inherited |
Appends a user-defined label to each scheduled snapshot and is blank by default. |
The following table shows Snapshots - Snapshots project properties.
Table 4-19 Snapshots - Snapshots Project Properties
Name |
Specifies the name of the snapshot. |
Creation |
Specifies the date and time when the snapshot is created. |
Unique |
Indicates the amount of unique space used by the snapshot. |
Total |
Indicates the total amount of space referenced by the snapshot. |
The following table shows Snapshots - Schedules project properties.
Table 4-20 Snapshots - Schedules Project Properties
Frequency |
Create time |
Indicates how often the snapshot is taken. |
Keep at most |
Create time |
Controls the retention policy for snapshots. |
The following table shows Replication (Inherit from project)/Create New Actions project properties.
Table 4-21 Replication (Inherit from project)/Create New Actions Project Properties
Target |
Inherited |
Identifies the replication target system. |
Pool |
Inherited |
Specifies the storage pool on the target where the project will be replicated. |
Export data path |
Inherited |
Indicates the export data path. |
Limit bandwidth |
Inherited |
Specifies a maximum speed for this replication update (in terms of amount of data transferred over the network per second). |
Enable SSL-encryption |
Inherited |
Controls whether to encrypt data on the wire using SSL. |
Disable compression |
Inherited |
Controls whether the compression is enabled or disabled. |
Include snapshot |
Inherited |
Controls whether replication updates include non-replication snapshots. |
Retain user snapshots on target |
Inherited |
When set, keeps user-generated snapshots on the replication target. Continues to retain snapshots on the target until disabled. |
Include clone origin as data |
Inherited |
Controls the replication of each share that was cloned from a share that is external to the replication package on the target. |
Recovery point objective |
Inherited |
Specifies the maximum tolerable amount of data loss in the event of a disaster or major outage. |
Replica lag warning alert |
Inherited |
Specifies a limit, represented as a percentage of the RPO, when a minor alert is generated. |
Replica lag error alert |
Inherited |
Specifies a limit, represented as a percentage of the RPO, when a major alert is generated. |
Update frequency |
Inherited |
Controls whether this action is being replicated continuously or at manual or scheduled intervals. |
