Using the CLI to Configure Networking
Network configuration is under the configuration net path, which has subcommands for devices, datalinks, interfaces, and routing.
Use the available command to see what values can be assigned to the links property when creating a network component, as shown in the following example:
hostname:configuration net interfaces> ip hostname:configuration net interfaces ip (uncommitted)> available igb0,vnic1
