Cabling Mixed Oracle Storage Drive Enclosure DE3-24 and DE2-24 Disk Shelves to Oracle ZFS Storage ZS9-2 High-end (HE) Controllers
Oracle Storage Drive Enclosure DE2-24 disk shelves with the following drive types are supported by Oracle ZFS Storage ZS9-2 controllers:
LFF HDDs
H7280A520SUN8.0T
H7280B520SUN8.0T
H7280B524SUN8.0T
SFF HDDs
H101860SFSUN600G
H101812SFSUN1.2T
H1018124FSUN1.2T
Write SSDs
HSCAC2DA6SUN200G
HBCAC2DH6SUN200G
HBSAC2DH6SUN200G
HPCAC2DH6ORA200G
HPSAC2DH6ORA200G
Read SSDs
HSCAC2DA2SUN1.6T
HBCAC2DH2SUN3.2T
HBSAC2DH2SUN3.2T
Refer to the diagrams in this section to upgrade or add to a system with Oracle Storage Drive Enclosure DE2-24 disk shelves by introducing one or more Oracle Storage Drive Enclosure DE3-24 disk shelves. In the following diagrams, the Oracle Storage Drive Enclosure DE2-24 disk shelves have three I/O Module ports, while the Oracle Storage Drive Enclosure DE3-24 disk shelves have four ports. See Cabinet and Cabling Guidelines for disk shelf intermixing guidelines.
Adding Oracle Storage Drive Enclosure DE3-24 disk shelves to an existing Oracle Storage Drive Enclosure DE2-24 storage configuration requires SAS-3 cabling and retains the legacy cabling and methodology if possible. In most cases it is easier to re-cable using the new cabling methodology. Use active optical cables (AOCs) to connect Oracle Storage Drive Enclosure DE3-24 disk shelves to the controller, and use SAS-2 copper cables to connect Oracle Storage Drive Enclosure DE2-24 disk shelves to the controller. The following examples illustrate re-cabling configurations with Oracle Storage Drive Enclosure DE2-24 disk shelves to accommodate Oracle ZFS Storage ZS9-2 HE controllers and Oracle Storage Drive Enclosure DE3-24 disk shelves.
